FOUND ‘71 window guide
popslavaz
11:00 PM
Channahon IL.
Feedback: 15 / 0 / 0
I need one window guide for ‘71 RR.Picture shows where it goes.
Do you know if 72's are the same? If they are I should have a couple extra that you can have. Are you talking about the metal piece with 2 bolts in it or the adjustable one bolt that is also a stopper. I should have both but will check tonight when I get home.
It's all those pieces, that can be challenging to find for a build or resto. I'm looking for things, daily.
The piece I need is the single bolt adjustable one. It should have a fuzzy-fur pad on glass contact area.
I should have those exact ones at the house. When I get home, ill shoot a pic to make sure its the one you need. If they are, they are yours free.
Mine are different than the one pictured.But that is basically the part I need. The ones on the passenger door look a bit longer and the brake sharper.I will try to get a better picture.
Big thanks for all reply’s . No way I could put this car together without all the help here!!!!
