SOLD 14 " wheels and tires
randys4406
10:25 PM
Mishawaka, Indiana 46544
Feedback: +36 / =0 / -0
Two sets of 14" wheels that take the larger dog dish hub cap. If you have an early 60's car, these are the wheels you need.
Your choice on the set $80.00 for set of four. With or without tires.
located in north central Indiana
The wheels are at a storage barn, I will check for numbers the next time I am there. I didn't think the 67 and older wheels that took the 9-3/4" caps had part numbers , or date codes, stamped in the rim.
My interest is in 5.5" wide rims. Often, the rim width is stamped on the wheel somewhere. Do you know the tire size?
I think on the 66-67 wheels I had you had to remove the tire to get the width. Its stamped inside under the tires.
Here is what I have found on the wheels. All are 5 on 4.5" bolt centers
The black set as follows
One wheel is 5.5" wide with a 3-1/4 " back space. At the stem is DOT 9 30 K 2
7
T14 x 5.5 It appears to take a 10" cap , my 9-3/4 " caps would not fit.
Three wheels are 5.0 " wide with 3-1/4" back space . At the stem is 5 on one side and 0 on the other. 9-3/4" caps fit these wheels.
The silver set as follows
Four wheels are 5.5" wide with 3-1/2" back set. at the stem 5 on one side and 5 on the other. All take the 9-3/4" caps.
I have taken more pictures. If interested, PM with an e-mail address for more pictures.
