slick
Selling a 1957 Plymouth dual quad 318 poly small block intake manifold and original set of 1957 1958 WCFB Carter 4 barrel carbs. The carbs are LOCKED UP, they will need rebuilt or used as cores. The Airhorns are both marked 6-1310, the front carb is stamped 1306 and rear stamped 1307. One of the air horns is messed up, a screw broke off in the cover plate and then the extractor broke trying to remove it. There is a C with a large circle with a smaller circle on both carbs. Both main WCFB bodies have a number 0-158 them. They appear to have left outdoors at some point or in a leaky barn and have some corrosion. They both have parts that could be used to restore another set. The casting code on the intake is 1822004 and the Date code is E 14 7 which is May 14th day of 1957. This code is consistent with 57 Fury which is the exact same setup used on Christine. $550 for the setup.
