SOLD 1963 426 Max Wedge Engine and Transmission
bb70duster
12:25 PM
Hemet, California
REAL 1963 426 Max Wedge Engine, 11.5-1 Engine, complete minus intake/carbs, and exhaust manifolds... It has the heads, rockers, oil pan, swinging pick-up, pulleys, balancer, water pump housing, even the original water pump with phenolic impeller, All original internals (aside from Cam is Isky) push rods, lifters, all bolts, starter, original Distributor is there, and have the original 727 with converter and flex plate (all MW specific) from behind it... even the trans cooler lines... Block is standard, has original pistons, rod, crank, even the bearings out of it... Block does have 2 rusty cylinders, but again, its still standard. I also have a set of factory high compression pistons in good shape Ill include, as well as a new set of aftermarket pistons (believe they are Jahns) Asking $8K If anyone is serious, contact me and I can get more detailed pics of everything... Pic of the 63 Plymouth is the car it came in... Mike PHONE NUMBER REMOVED BY STAFF
Was not aware that any maxwedge blocks where painted that color,somebody school me!
