1963 B-body Dash Harness Bulkhead Connector Supplier
friendofvirgil
11:06 AM
Glendale, CA
Does anyone know if someone is manufacturing the 1963(maybe 1962 also?) bulkhead connector for the dash harness? Part Number is 2258497. I see Herbs Parts has the fuse block Part Number 2291593 that's common for 1963-1969 A and B bodies and a 1964 B body bulkhead connector but nothing for 1963. The bulkhead connector is in the second picture, then on the right side.
I needed to clean up my '63 block, like yours, so I soaked it in Evapo-Rust, and it came out pretty decent. I have not found a replacement for it, nor the dash harness either...
Had some ills with my BH on my '63 and the block. I re-did the fuse block to protect the connectors from contacting each other with some new encased connectors. A not best job; but functional - a best job is new dash harnesses with upgraded BH and fuse block. I had hunted around for a BH but didn't have luck. Have a new engine harness and cleaned up the BH until such time more needs doing. Hanging around to see what you might come up with.
