1963 plymouth push button cables
If they're leaking where the metal sleeve meets the plastic housing covering you can use shrink tubing to fix them. Clean the area super clean then install the shrink tubing and apply heat. Only use the tubing that has glue inside of it. Works like a charm.
I've fixed a bunch of them with heat shrink. None leak.
Doug
You have to remove the cable from the trans. They usually leak at the crimp. The shrink tube straddles the metal crimp and the casing. If you have a damaged area of the casing you can sleeve that as well. I use ES-3 shrink tube that has glue inbedded in it.
Doug
