1964 Dodge Model 440 - Max Wedge
SpeedyGreek
5:37 AM
Michigan
This Beautiful 1964 Dodge 440 two door post Max Wedge recreation is a turn key Nostalgic Race Car that has done very well on the track. This car had run in the Chrysler Classic Events. It has run a best E.T of 10.27 @ 131 MPH. There was NO expense spared building this car.
Engine : 1968 440 cubic inch block bored and stroked to 496 cubic inch,
Bronze bushed lifter bores
Hard filled block
Main oil galleys machined oversize
Cam bearing oil passages with oil restrictors
Gear drive timing with MSD crank trigger ignition
Heads : Indy cylinder head 440-1 milled to 70 cc combustion chambers.
Compression ratio: 14.0 to 1
Pistons: Ross forged flat tops .005 above the deck surface.
Rods : Eagle H beams
Crank: 4.150 stroke forged Eagle
Cam: Straight line Performance .671 lift, 306` duration
Valve train: Crower roller lifters, Harland Sharpe roller rockers,Isky tool room Springs 300# seat pressure, 700# open
Best E.T. 10.27 @ 131 M.P.H.
Body: 1964 Dodge model 440 two door post car. Front and rear frame rails are tied.
Torque boxes at front spring hangers and at front cross member, all welded in place.
Front fenders, hood, and front bumper are fiberglass. Chrome rear bumper. All chrome and trim is in excellent condition.
Interior: Completely finished with radio delete, trans delete, and heater delete plates.
Original A100 van bucket seats with adjustable driver side seat track. Complete rear seat
Delete panel with full carpeting. B&M mega shifter ratcheted type with reverse lock out. All door panels and rear side panels are new from Gary Ball. There is no heater box or windshield wipers on the car.
Lubrication: Milodon 10 quart oil pan with swinging pick up and windage tray, with high volume Melling oil pump, single line.
Transmission: Built by A&A transmission with billet front steel drum, ultimate bolt in rear sprag, heavy duty pump gear, reverse manual valve body, billet low reverse piston kit heavy duty band strut with 4.2 lever, red friction bands, modified pump support and body, 5 pin all steel full bearing front planetary, 4 pin aluminum rear planetary full bearing, low roller kit (rear support), full bearing low/reverse drum with lightened sun shell. Deep cast alum. Pan with billet alum. Filter extension. Dynamic 9” 5000 stall converter with carbon graphite trans shield. Total cost for this set-up was over $5000.00 I also have original order for this transmission, with the specs. All transmission lines are braided flex lines.
Drive shaft: Dyno tech Matrix metal light weight shaft with heavy duty universals.
Rear end: Strange engineering 35 spline axle with spool. 4.30 Pro Dana ring and pinion gear set. LPW ultimate cap support cover. Cost $2695.00
Brakes: disc brakes front and rear.
Shocks: front 9 way adjustable, rear 9 way adjustable heavy duty with mono leaf springs and Cal Trac suspension.
Fuel system: 10 gallon aluminum fuel cell with aero-motive electric fuel pump, part #11202 (race only) with 10AN inlet/outlet ports. Flows 350 gph. Kinsler fuel injection billet 5 micron stainless steel mesh fuel filter (serviceable). Magna Flow fuel pressure regulator mounted in engine bay with 6AN fuel lines to the carburetors. Carbs are duel Edelbrock 750 cfm with no chokes.
Induction: Original 1964 Max Wedge cross ram intake.
Electrical system: duel trunk mounted Optima 1000cca sealed batteries ( new 2010) battery cut off switch at rear of car. MSD pro billet distributer with MSD 7AL-2 box and crank trigger ignition. Mopar light weight high torque starter, Moroso electric water pump, duel electric fans on radiator, Holley front brakes line lock. No alternator. Everything is controlled by Bosch relay switches wired to lighted toggle switches mounted in the dashboard.
Cooling: radiator 26” aluminum with duel electric fans, 24000gvwB&M trans cooler.
Headers: TTI step headers 1-7/8 to 2.0 inch, ceramic coated to 3” header extensions, with crankcase scavenging system.
Tires: Front, Goodyear front runners 28”x4” on Centerline polished aluminum wheels.
Rear, Phoenix 30x9x15 mounted on 10” steel wheels. All tires are new with less than 10 passes on them.
The pictures do not do this car justice. If you want a TURN KEY RACE CAR (that looks like a show car), without spending the money it takes to build one of this quality, you may want to consider this great car.
http://s1218.photobucket.com/albums/dd414/SpeedyGreek/
$34,900 or Best Offer
Looks like a fun ride
Speedygreek,
I think I met one of your friends at a car show in Fort Myers a few months ago, he told me about your car being for sale...........nice ride, a little above my price range.
I am open to trades of some kind.
This car is every bit as nice as any out there, no disappointments, best of everything.
fwi, I have listed this car for a friend of mind who is currently battling an illness. He had no intention of selling this car, however due to the circumstances he was forced into it. We are members of a large Mopar Club (North Oakland Mopar Muscle) up here in the Metro Detroit area and he has several friends that travel south (your "sunny place for shady people" :) ) . in the winter. You had mentioned a trade? What do you have?
I have a 63 Dodge Polara 426 wedge
Bump... this beautiful car is still available. Price reduced to $33,000 or best offer.
Nice car!!!Good price...Here,s another bmp...
Petty Blue 67 gTx
to anybody who has that kind of money now a days, it's a steal. Beautiful car, That is exactly how I wan't mine to look when I'm done with it.
He's improving but knows he's not going to jump into this car again... Thanks for asking.
I don't know the seller but you can't build that car for what he's asking.
Hell of a deal!Just wish I could house another racecar allready have two now! Hope the owner keeps improving! Have you listed it on racing junk.com,or Nostalgia Super Stock .com Good luck with the sale!
Thanks guys. The car had run in the Nostalgia Super Stock series in the Midwest and had taken 10th in points 1 year in the few times it competed in a full season. It currently needs nothing. It is a turn key race car with 3 passes on a fresh motor. As most people know who build these cars... there is more in the drivetrain than he is asking for the car. This car really needs to be seen to see the quality put into building it. I had listed it on racejunk.com and will look into listing it on nastalgiasuperstock.com (which looks like the perfect place for this car). Thanks again.
