1964 Fury Wagon Rear Window Problem
moparmama
11:00 AM
Montrose, CO
I have a 1964 Plymouth Fury Station Wagon. The rear window is electric and has quite working. It is in the down position. I have removed the inside tailgate access panel, however, the glass is obstructing me being able to access the motor and wiring. Any suggestions?
Can you get to the bolts that hold the metal support of the glass to the regulator assy? Usually these come off and the window can slide out allowing access to the regulator assy. Another thing is if you have a connector in the harness outside the gate somewhere you might be able to bypass the switch and run the motor to move the window (assuming the problem is in the switch).
Sell the car to me, I'll take care of it.
Does it have a manual crank feature?
