1964 Polara 426 wheel bolt pattern
Odmark91
3:35 PM
Sweden
Hello! What is the wheel bolt pattern for a 1964 Polara with a 426 Wedge?
What size are the threads? I just got hold of a set of Centerline wheels that im going to put on it, but i need to order nuts. 1/2-20?
Same as Ford , Chevy got the 5 on 4 3/4" measuring from the center on one stud to the outer diameter on the stud across from it . 6 bolt measures center to center.
Thank you all, i got the Centerlines home last night and just ordered the correct nuts.
Thank you all, i got the Centerlines home last night and just ordered the correct nuts.[/QUOT
Remember if the original studs have not been changed the left side (drivers) is left hand threated. It will be marked by an "L" on the stud
