FOUND 1964 polara 500 parts needed
barracuda67man
12:10 AM
new york
Feedback: +1 / =0 / -0
Just picked up 64 polara 500 and need some parts that are missing. Front hood and trunk DODGE letters/c pillar emblems/door arm rests in black/interior rear view mirror/black dash pad/ the top cover to the inside of the doors in black that the door locks go thru and fit against the windows/right rear tail light/front bumperettes/polara 500 fender emblems/radio/and most importantly...if anyone knows of where to purchase a complete molding clip kit for all the side trim that would be a big help as owner took All moldings off car and left No trim clips..... I know they make some aftermarket parts for some of this but wanted to go good used first...Thank you in advance for any help....
Information on the molding clips is all I can help with. I am a new 64 owner and haven't collected too many parts. The side molding clips are almost unobtanium. Try RT Specialties and Layson's. When I needed some, Layson's usually stocks them but were out of stock then.
I'll look through my stash in the AM. I believe I have some of these items. I'll report back tomorrow.
Thank you Toolman......Laysons couldn't help me but RT specialty knew exactly which ones I needed ...not cheap by any means but when you need and find it...grab it... My journey begins.....
I found some stuff on the list and some needs better clarification. Do you need just the arm rest pads, or do you need the bases also? On the door panels do you need the metal caps as they are usually attached to the door panel and covered in the panel vinyl? Here is what I have but am still looking as I could have sworn, I had more C pillar emblems. Start a PM if that is more convenient.
