FOUND 1964 polara 500 trunk moulding fasteners/clips
You mean the 2 strips on top? They had studs, that usually break off.
Yes.i need those..took mine off and were missing completely so over the years someone just used the ones on the ends to hold them on
So you're looking for some rotted off pot metal studs?
It's like an emblem. When the studs are gone they're gone. I've seen people use a very discreet screw in the groove of the trim. A thin strip of black vinyl and you should be good.
Remcharger...that's incorrect..they are square slotted fasteners with a stud attached to each one that slides into the back of the molding from The widest edge and down into the grooved molding. If you want to see what I'm talking about there's an nos molding on ebay right now showing this and dave6t4 also confirmed this..r/t specialties is looking for me..thank you anyway.
Thank you for the correction barracuda67man. I couldn't find the link ,but I'll keep my eyes open.
Happen to have a picture of one? May know of a source.
Here is what they look like. About 7/16" square.
If you're handy at all, and can't find replacements, you could make your own. Source some threaded rod of the correct size, then cut to length. Get a piece of sheet metal and braze a few of these rod sections to the sheet metal then trim the base to size.
