WTB 1965 coronet 383 kickdown parts
max426
3:38 PM
pa
Feedback: 3 / 0 / 0
Wanted kickdown rod, throttle cable bracket, return spring bracket.
4BBL Carb
jim
4BBL. edited
Hard to find stuff. 4 barrell different than 2 barrell. When I switched my 64 Fury to a 4 barrell, I ended up finding one from an Imperial in a 'yard and modifying it to work and look the same.
Would a 64 rod be the same as 65?
I would think it is the same. I'll check in parts book.
That setup is a later unit! The 63-64 65 Had a one piece rod with a threaded ball clip on the carb end no bell crank! shown is a 66-67
Your most likely right. I have no Idea what year the engine was. It was painted "Ford Blue" The car was a 64 Dodge at a wrecking yard.
