SOLD 1965 Coronet 500
diamonddean
10:23 AM
Shelby Township, MI
Feedback: +0 / =0 / -0
65 Coronet 500 roller with original cable shift trans, powersteering, front disc brakes, electronic ignition w/distributor. No engine. Was 383. Have alternator, fan & drive shaft. Has full dual exhaust to rear bumber. PST Polygraphite full front suspension kit & front sway bar w/mounting brackets all still in packages. First $10,000 takes above!!.
New 15" Wheels Vintique black steel wheels mounted with Mickey Thompson Sportsman S/R Tires. $700.
New 1 7/8" x 3" ceramic coated Hooker Headers. $350.
Also have a freshly assembled by Muscle Motors 450 CI low deck short block stroker with Hughes Engines .536/.546 cam (PN SEH3236BL) double roller chain & set adjustable push rods, Summit Racing damper, Melling high volume pump, Milodon 7 qt pan. $5100 Invested, will sell for $4800.
New in box JW 11" 2800 stall converter. $350
First $14,000 Takes everything
Shelby Twp., MI
No rust issues. Pictures were taken when I brought it home one year ago. Removed motor to have stroker built up and block was cracked in upper main journal area. Never would have knew when I was driving it. Wasnt the original #'s motor.
Where you located ?? Sorry i see now.
Very Beautiful car! Sorry I can't scoop it up. Good luck with the sale.
