fwi
1965 Coronet 500 from the Lynch rd plant.
1969 440 block .030 over, Mopar triple spring .530 lift hydraulic cam, steel crank, 450HP, 9.5 to 1 compression, Holley 750 double pumper on Edelbrock Torker intake, Garlits velocity stacks (not real F.I.).
MSD7-AL2 ignition, MSD Pro Power high voltage coil, MSD Pro billet distributor, MSD 8.5mm spark plug wires. 26" aluminium radiator, Flexlite 14" electric fan in addition to regular fan, alternator cutoff switch.
2" custom headers into 3.5" collectors (could use replacement as the #4 pipe has a leak).
TCI 727, reversal manual valve body, 9" converter, 3500 stall, transbrake, line lock, SCS Cheetah turbo shifter. Chrysler 8 3/4 posi, 4.10 gears.
Front disc brakes, rear drums. 15 gallon fuel cell, Holley blue pump.
Tires: rear M/T 8.20-15 on 8" black steelies, front Moroso 7.10-15 4PR on American Racing Torque Thrust D's.
The car is all steel, no rust, all window glass is good, all chrome excellent. Super clean car. very straight body.
Interior is original, all lights work. Very comfy seats Dodge A100 style (not sure of origin as I didn't build this car).
Even more street legal if you add mufflers and street tires. Registered and insured. Clean title.
$17k/offer
Will consider trades.... (gasser/3 window coupe/porsche/etc...
$17k/offer
