1965 Plymouth belvedere disc brake conversion on a budget
Filipw
New Member
2:04 AM
Sweden
As the headline says im thinking about putting disc brakes on my belvedere, but im on a rather thight budget. So my qustion is, can i use spindles and brakes from another make/model? The kits you can buy is waaay to expensive so finding some used spindles would be great!
Best regards fron Sweden
Disc brakes
You can use the disc brakes from 73 to 76 Dart,Valiant and check Mopar Action tech section ( Disc o tech ) the the article gives you all the information.
Jeff
76-80 Aspen / Volare will also work, all the brake pieces are the same but the spindle is a little taller. I know of people using these and not being able to tell the difference (of the taller spindle). I used 75 Valiant parts on my 65 Belvedere. You will not regret changing to front disk brakes.
