WTB 1966-67 Charger door lock link rod
Striker251
1:21 PM
Long Island, NY
Feedback: +0 / =0 / -0
Need 1966-67 Charger door lock link rod.
Seems all they reproduce are 68 and up.
I need driver side but will buy both if selling as a set.
Thank you
Thanks, if I can get a clear pic of the driver side. I can probably recreate using same thickness rod.
Would you have good pics to show?
I do not have pictures of this item. I would like to get good pics so I can recreate the part using a steel rod of same length and thickness.
It's just a hair under 7" from end to pin hole. Slight bend as it comes out of the lock
I have done before. I found that the wire handle on a five gallon bucket works well. Slightly smaller diameter but strong
Enough and the factory nylon guide/lock grips it.
