SOLD 1966 / 67 Charger grill in Canada
gdrill
Just enjoying "B"-ing here
8:33 PM
Stuck in the past, just North of Montana....
Feedback: +3 / =0 / -0
This is fairly complete as far as I can tell and it comes with the engine bay harness. I was going to convert a Coronet and changed my mind. The center grill section is bent and will need replaced. You may be able to straighten it to driver condition. I don't want to separate. I was told it all worked when I got it. I haven't tried it but the motors and wiring look fairly good. I don't know how to bench test it either.
$350 USD for everything.
Located in Alberta Canada
Will ship at buyers expense and my convenient opportunity, may be able to arrange it from the U.S. side of the border. It is surprisingly heavy!
Looks like it might be a '67 by the looks of the limit switch connections. Should be able to unplug the motors and hot wire them with 12V to see if they work. Connector has 3 wires, open, close and ground. The lower trim looks to be in nice shape.
Good luck with the sale.
