FOUND 1966-70 b body console mounting brackets
Todd Schuster
11:44 AM
Almont, Michigan, USA
Feedback: +1 / =0 / -0
ISO - really, just the front and rear brackets, which appear to be the same for automatic and manual. (yes, I know I can get new ones (the full set of 3) for $99 including shippment new thru ebay)
Anybody want to sell theirs for $50???
I have the front and the middle for 4 speed.....$40 shipped. PM me if interested. Joe
I thought the automatic and manual bracket sets were different. I have a set of automatic brackets from a 67 Coronet you can have for 50 plus large flat rate box which is 21.50
Thank you - I just got an offer local that I can go pick-up (no shipping) for $50 - I am going to look on Saturday, will let you know if falls thru!
Hi Dan,
So, I was not able to hook up with the guy, and now he's not answering me, so I will take yours for $50 plus shipping if you are still offering?
Thank you,
Todd
Hi Dan,
Thank you,
Todd
Todd send me your address, large flat rate box is 21.00,you can PayPal to d_juhasz@verizon.net
Underscore between d and j
I current removed the main bracket with a piece of the floor attached to serve as a template to locate it perfectly. Once it is located you can grind the welds off the floor and discard. From there attach all brackets to console body and place on floor aligning your scribe for main bracket, then you can scribe all the other brackets. Can’t miss this way.
Thank you - will send paypal now!
Please send to:
Todd Schuster
7669 Auburn Rd
Utica, MI 48317
I appreciate the instructions as well!!!
Just sent $71 via paypal...thank you agian!
Please send to:
Todd Schuster
7669 Auburn Rd
Utica, MI 48317
Thanks - if you could, please let me know a tracking number (going to try to coordinate my welding schedule!)
This is what I did with the main middle bracket. I drilled a pilot hole through floor piece and bracket as a locator. I then separated the old floor from the bracket. Lay the old floor on your floor lining up the round opening where shift linkage will pass through. Mark the 2 pilot holes with a pencil or spray paint to your floor. Your done with the old floor now. Lay the main bracket down aligning the pilot holes in bracket to marks you made on your floor. That will be correct. Attach other 2 brackets to console body and when you screw body to main bracket wherever the other 2 fall is correct. Good luck
