Ajax
For sale is a 1966 Plymouth Belvedere II. It is a Mopar B-Body and shares the same body as the 1966/1967 Satellite as well as the 1967 GTX.
$12,500
I purchased this car in 2009 and many parts needed to be replaced. Since I have owned this car, I have driven it mostly around town on weekends and I would estimate that I have driven this car an absolute maximum of 500 miles. I simply don't have the time to play with this car. The car has a clear title.
o 360 C.I.D. engine and a 727 automatic transmission.
o Edelbrock 600 cfm carburetor (I purchased and installed this new)
o Edelbrock Performer Intake Manifold (I purchased and installed this new)
o Edelbrock Elite Series Aluminum Valve Covers (I purchased and installed these new)
o I took the heads to a shop and had the heads inspected, a valve job done, mating surfaces polished, and new oil seals installed. (This was done when the new intake and carb. were installed)
o Headers are installed (they came with the car)
o H-Pipe exhaust (came with the car)
o Radiator was re-cored at time of car purchase
o Replaced the water pump, fan (replaced with 20" flex fan), hoses, thermostat, timing chain cover, and coolant reservoir.
o Battery, alternator, cables, voltage regulator, ballast resistor and ignition relay replaced. A wire harness of much better condition was installed.
o Replaced ignition system with electronic ignition conversion kit from Jegs.
o Replaced coil with new Pertronix Flamethrower II coil.
o Replaced leaf springs and bushings (purchased new from Mopar Performance)
o Replaced rear shocks with new Edelbrock Performer IAS Monotube Shocks.
o I purchased a front end suspension rebuild kit from performance suspensions that still needs to be installed.
o I purchased a front end disk brake conversion kit from Jegs that still needs to be installed.
While this car's exterior is in good condition, it does have imperfections. The interior is in good condition and as you can see, the seats, dash, carpet, and headliner are great. The glass is free of cracks and is tinted as well. The head lights, horn, turn indicators, interior lights work.
This is a great car and it is a joy to own but as I have mentioned previously, I don't have the time and it is not a main priority for me anymore
$12,500
