1966 Charger Auto console Top plate
QuickBpBp
5:38 AM
SE PA
Don't know a lot about 66-7 Chargers. Just a question to ask if the Auto console top plate with the luminescent light has any value. I have a nice one but I see none offered to base a value on...Also I assume 67 is the same top plate with the lighting... Thanks in advance.
Many of these top plates on E bay. You should get an idea of value looking at the various listings. They don't all include the EL shifter indicator assy. which is a desirable thing.
a 66 is same as the 67.
Thanks I looked and did not see one with EL shifter light or one with the aluminum insert only the ribbed style not used in 66-7 Chargers.... Otherwise with-out it, it is the same as used on some c-bodies.... Do you have any links to one with it? I did not find any...
67 did NOT have EL in the shifter, it was bulb. Console plates are the same but the shifter plate is EL in 66, bulb in 67.
I know they switched to a short style console in 67 instead of the long one used in 66. Thanks for the info on the lamp being 66 only.
Same on the console clocks. EL in 66, bulb in 67.
