Mike Gaines
- 9:25 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
1966 Coronet 440. Runs consistent 10.17 to 10.19 at 131+mph.
100% Street Legal.
Drive To Car shows, etc. Current California License Plates and Insured with Hagerty.
Turn Key, Peel off Vinyl Graphics and go.
Headlites, Horn, Turn Signals
Only about 100 runs on complete motor. 100's and 100's of drag strip runs (before freshen up) and 1000's and 1000's of reliable street miles left in Motor.
505" Ohio Crankshaft Rotating Assembly, H-Beam Rods, SRP Forged Pistons 12-1 Compression Ratio
8 Bolt Hemi Crank Flange with B&M 8 Bolt SFI flex Plate
INDY cast aluminum Valve Covers
440 Source aluminum roller tip Rocker Arms
Steel Billet Girdle PLUS Steel Billet Main Caps
Milodon 8 Quart Pan
Lokar Braided Stainless Steel Flexible Dip Stick
Block professional prepaid prior to assembly
Pump Gas OK for street driving although I run 110 Race Gas at the drags
Comp Cam Solid lifter Cam, Valve Springs, Retainers and keepers.
Ferrera Valves
INDY EZ MAX WEDGE heads ported to 340cfm. Fel Pro 1009 Head Gaskets
INDY Push Rods
Dougs 2" header with 3.5" Collectors. Complete 3" exhaust system with cut outs and Magna Flow Mufflers.
RemFlex exhaust manifold Gaskets. Mr Gasket locking header bolts
MSD Ignition, wires, Blaster 2 Coil, etc. Runs inexpensive AutoLite AL3923 spark plugs
Timing varies between 34 and 37 degrees depending on Adjusted Altitude.
Runs Valvoline 20-50 Race Oil and Wix Race Filter
INDY Single Plane intake with 1050 Dominator. Jetted 92/92 square
Holley Black Fuel Pump
Aeromotive In-Line Fuel Filter
Torqueflite Trans (reverse pattern) with all A&A parts including trans-brake. Runs Lucas Synthetic Trans fluid.
Hurst Shifter 1/4 stick/pistol grip
Jegs Line Lock
Jegs SFI Transmission Blanket
Moroso Steel Motor Mounts, new rubber mounts included in sale.
3" DOM drive shaft with BIG Steel billet yokes on both ends.
Drive Shaft Safety Loop
RCI Cam-Lock Seat Belts good thru June 2019
MSD 6AL with plug in 3-step module. 1 5000 chip for water box, 1 3600 to 4000 (your choice) chip for trans-brake launch, 1 7000 chip for top end rev limiting...goes thru traps right at 7000rpm when top speed is 131.50+.
Ultimate Converter with 5000 flash, 100% streetable.
60 Amp 1 wire Alternator with 5" pully
Meziere Electric Water pump PLUS regular pully driven water pump included in sale.
Giant B-COOL Radiator with twin 16' Spal Fans.
Fans controlled by either thermostat switch set at 180 degrees OR Manual On/Off switch
B&M Transmission Cooler
4.30 DANA 60 Rear End with all Moser Parts, axles, etc.
T/A aluminum Differental Cover
Disc Brakes front, 11" Drums Rear.
Complete front end suspension rebuilt.
All windows are in place and roll-up and down.
Weld wheels, 15x10 and 15x3.5
Moroso 3" Long Wheel Studs both front and rear with McGard open end lug nuts
Rear is Mini-tubbed with inboard spring hangers to accept 15x10 wheels and big tires. No Back Seat.
Tires: Rear 29x10.50 18175D06 Stiff Sidewall Bias Ply Hoosiers with M/T tubes
Front Moroso 28" DS2
Complete Cal Trac setup..Cal Trac Mono-Leaf springs, Cal Trac Bars, Cal Trac 9 way Adjustable RR shocks and Cal Trac 90/10 front shocks.
US Body Frame Connectors
Autometer Memory Tach and Gauges (Voltmeter, Oil Pressure and Water Temp) Autometer cowl mounted fuel pressure gauge.
Dual Optima Batteries with Billet Hold Down Brackets
Rear bumper remote charging studs.
5 Gallon Aluminum Fuel Cell plus 12 gallon Harwood Poly fuel cell included
Rock Solid Chassis on a never rusted body.
OEM Steel Decklid Plus Sled City Fiberglass Pin on Deck Lid included
Two different GlassTech Hoods. 1 heavy duty fiberglass for more street use plus a light weight hood for Drag Racing.
2 different scoops, Harwood Pro Stock Style (with plug) plus RO Hemi 5" scoop. Both GlassTech
Call for any details.
Put on a set of street tires and make it a street car OR leave it a track car and drive to car shows the way it is....just hook up the complete exhaust system.
Thousands and thousands invested.
Included is extensive log book recording EVERY RUN on car with incremental ET's, MPH, Temperature, Adjusted Altitude, etc, etc.
NOTHING overlooked on the build of this car.
$29,900.00
Cash or bank transfer
PM me for Phone number and call anytime.
Car is located in Ahwahnee, CA about 40 miles north of Fresno, CA.
Will deliver car to new buyer within 250 miles.
100% Street Legal.
Milodon 8 Quart Pan
Ferrera Valves
INDY Push Rods
Jegs Line Lock
$29,900.00
