Well in that case, any reports on how effective it is?Some say noise silencer some say heat protection.? I lean towards the silencer.
Why? Because the factory part doesn't have a smooth side, both sides are rough. And it's molded so it can only go on one way.why would the smooth side go up?
Even with the molded hood pad if you use any type of spacer on the carb/manifold it will be a brillo pad....prev owner did just that with mineWhy? Because the factory part doesn't have a smooth side, both sides are rough. And it's molded so it can only go on one way.
That aftermarket piece of **** he has is 2 inches thick, it will be like an SOS pad on your 440 GTX pie tin, and that's a $500+ mistake these days,
