1967 Charger 383 Drivers side exhaust manifold
Tony Jaramillo
New Member
11:26 PM
Virginia
Hello, Does anyone happen to know the part number of this manifold? Restoring the car and found that the drivers side manifold has a hole in it.
Also if this one is hard to come by other then using headers will any other stock manifolds work on this car.
Thanks for your help.
Depending on how big a hole you have, it can be repaired by a qualified welding shop.
Yea, good size rust hole. Can cast be welded?
The biggest problem with a cast iron exhaust manifold is the thousands of heat cycles that it has gone through depletes any temper in it. Cracks can be welded with nickel or brazed with a torch but sometimes it's temporary as it goes through more heat cycles. Rust removes temper from steel or cast also, so trying to heat it enough to repair can be difficult. Not saying it can't be done but a good replacement might be a lot easier. Jmo
Thanks for the reply's. I would rather go with a replacement if possible. Thank you for the part number list. Just wasn't sure if different manifolds would work for this car.
Most muscle era big block manifolds would fit your car, but the flange angle changed several times, so you would probably have to modify the head pipe.
