Joseph Lenehan
1967 Dodge Coronet RT 440/375hp Magnum, Complete 2 yr old restoration. Rebuilt correct date code 440 engine, rebuilt original 727 transmission Stage II stift kit, rebuilt 3.23 SG rear and axles, rebuilt new front end, upgraded to new disc brakes, new gas tank, new fuel line.. and on and on..Detailed undercarriage. This is a real WS/ RT with its original fender tag, All body codes match. Comes with copy of original Texas title from 1977. Car was completely stripped and sanded down. There were a few rust holes in the floors and trunk. So rather than patch them they were replaced with whole floor and upper trunk pan. The rest of the car was solid. It is painted in its original Cream Pale Yellow and the paint is show quality and stunning. All the trim with exception of the drivers door mirror, door handles and rear C-pillar trim are original. The body is clean and straight as to factory, The Interior is very nice and correct with the bucket seats and center buddy arm rest still like new and with solid form cushions. They are extremely nice and not faded, cracked or split. The carpet, door panels, headliner and scuff plates are new repo. The dash is 100% original and very nice. The clock and radio does not work but all the gauges work, and lights, The engine is the original engine. C-440 HP. The assembly date pre dates the production date by 3 weeks. Original 936 radiator, original exhaust manifolds. There is an edelbrock CH4B aluminum intake with a new Holley 750. The transmission is also the original to the car and rebuilt, shifts crisp B&M shift kit stage II. The engine has the correct 915 HP heads and are set up to run unleaded. There are forged .030 forged flat top pistons in there and a 9.0 compression so you can run 87 octane. Complete new wiring harness and several other parts normally changed to this level restoration. It never runs hot even on 95* days. It truly is a pleasure to drive, starts on the first crank and It drives straight, stops straight and is a remarkable car. New 15" Goodyear Tires 225/70frts and 255/60 with 15" Magnum 500 wheels, New dual exhaust from front to back, new front disc brake conversion, new rear brakes etc etc ect..... Asking price 26,800
