SOLD 1967 Dodge Coronet R/T
Dodgerebellion
10:45 PM
illinois
Feedback: +0 / =0 / -0
1967 Dodge Coronet R/T 440 4 speed. 1 of 1360 produced with the 4 speed transmission. Has dana 60 rear axle with 3:54 gear. Transmission has C-97372 cast on the case with no vin pad.
Car has '72 440 short block in it now that does rotate. I have a correct '\cast date '67 HP block that goes with but need repair. Standard bore, tanked, and checked for cracks. Both ears on the block are broken and would need a donor block to weld repair at a shop that specializes in welding cast iron.
Frame rails are solid accept for 2 holes in the torsion bar crossmember. Drivers side inner fender well has a cut out. Maybe for a fender well header. Drivers side front floor has some rust. Trunk is solid with the usuall rust around the wheel wells. Dent where right side quarter panel meets the door. I have the original console tach that has been repaired , new rear window, rebuilt correct carburetor, 915 heads, correct radiator, fuel tank, intake manifold.
I can take more pictures of where you need or send pics.
Car is located in Illinois. 60531
$16,500. obo.
