1967 Satellite Hardtop Info.
transman
1:09 PM
Western Canada
Hi guys. I will be taking a drive out of town in the next couple of weeks to look at a 67 Satellite hardtop, and I would like your help. I presently own a 74 Challenger, and pretty much know where to look for rust issues that aren't always obvious. However, I don't have much knowledge on the Satellite and where one should look, so any information would be much appreciated. Also, are there other things that this car would be prone to that I should be aware of, ie are parts difficult to locate? It has a small block V8 in it, and drum brakes, so the brakes will be changed over to discs in the front. Any one done this and other than some of the big name companies, is there a later year Mopar that has discs that could be swapped into this car. I want to keep it all MOPAR if I can.
Any and all information much appreciated.
Thanks in advance.
Prone to rust inner and outer cowl area outer ends, front windshield lower channel, rear window channel especially at lower corners, lower fender area,front wheel rear splash shields, under battery tray, front drivers side frame rail under battery tray and brake master cylinder area, torsion bar crossmember, bottom of doors, lower quarters/outer wheel house area, sheet metal directly behind rear bumper, rust from interior of trunk pan, rear deck lid seams, usual floor pan foot wells.
