1968 440 Block without VIN
BelvedereII
5:42 PM
Nebraska
Just bought a '68 440 block/crank/rods/pistons setup as a spare to stick in the corner of the garage (or maybe use the crank in a 400) and can't find a VIN stamped in the block. Where should this be located? I was thinking along the bottom of the skirt just above the pan rail on the passenger side.
It's a 2536430-2 version, stamps on the i.d. pad are D440 for 1968, HP2 (I thought it was only supposed to be HP?), the numbers 3 and 28, then an "A" on the driver's fender side to indicate .020" over. On the side, the "sundial" is pointing up at 12:00, the N (night shift?) is selected and the date is 1-27-68. Is the VIN cast on, or stamped in like a transmission number?
B II
Nevermind, found it at the rear of the motor by the oil pressure sending unit as 8B341250.
Yep, in 68 that's where you typically found that. The tranny was stamped on the top of the bell housing right next to where you would find the block number.
