FOR SALE 1968 B Body non rallye dash harness
'68 Charger
5:15 PM
Akron, Ohio
Feedback: +84 / =0 / -0
For sale is a 1968 B Body non rallye dash harness. For the most part this is a good harness. Ideal if you don't want to spend the big $$$ on a new reproduction one. The flaws are the headlight switch plug terminal has been removed. No wires were cut in doing so, each wire was removed from their cavity of the plastic plug terminal. Also it has the 2 typical lead wire (black & red) defects in the bulkhead. Finally the low beam/high beam floor switch terminal needs attention (new housing). I believe I have another housing for the floor switch that I can include with purchase. Most of the wires are in good shape, no hacks, cuts or burns with exception of the bulkhead and I think just the plastic got damaged.
Overall like I said this can be ideal if you're on a budget. They do sell new bulkhead terminals. Evans Wiring has them. As far as the headlight switch plug terminal I don't believe that those are available reproduction, used only. And for the floor switch I will try to locate it and include it with the sale of this harness as well as put up a pic of it in here.
$50.00 + shipping.
Just an FYI new ones go for: C.I. $469.99 and Y.O. $519.99 WOW
http://www.classicindustries.com/product/mopar/b-body-coronet/parts/mb2443.html
https://www.yearone.com/Product/chrysler-b-body/hu268b
This is for 1968 B Body with oil light (non rallye)
Thanks
20161122_001305.jpg 20161122_001311.jpg 20161122_001316.jpg 20161122_001339.jpg 20161122_001344.jpg 20161122_001349.jpg 20161122_001458.jpg 20161122_001404.jpg 20161122_001510.jpg 20161122_001524.jpg
Floor switch plug housing. I can install with the sale of the harness at NO extra cost. No cut and splicing. I will remove the wires from the defective plug and the pigtail plug. Then re-install the harness wires for the floor plug into the pigtail housing.
