Mike Szadaj
- 10:07 PM
- Jan 17, 2019
- St. Clair Shores, Mi
The question is, how could they make such an egregious mistake?
The people designing these are either foreigners or they just lack the sense of detail that aficionado's possess.The question is, how could they make such an egregious mistake?
Here is what I do to help keep the lines straighter on the trim. I use the thinnest fine line tape available as a guide.It helps a lot if your like me and have shaky handsThe stainless trim is Bare Metal chrome foil, which is sticky on one side. You measure the length of the trim you want to cover, and cut a strip slightly wider than the trim. You press it down with your finger, and burnish it with a Q-tip. This shines up the chrome, and firmly presses it in place. You trim the foil to the correct size by running a sharp Exacto knife blade down the molded chrome trim lines. For long pieces like side chrome, I do it in 2 pieces: front of front fender to rear of door. Then rear quarter from rear of door to end of rear fender. For small chrome bits, you can buy a chrome paint dispenser pen at hobby shops. Toothpicks are also my friends for daubing paint, like battery caps and other small painted items.
