- 12:30 AM
- Sep 5, 2022
- Mülheim an der Ruhr, Germany
For sale is an original 1968 Dodge Charger steering wheel set consisting of:
Restoration details:
Currently, 2 fully restored horn rings are available:
Horn rings and horn switches are not available as reproduction parts. A considerable amount of time, craftsmanship, and attention to detail went into this restoration — ideal for a high-quality, original-correct restoration.
If you have any questions, feel free to contact me.
$1500 shipped.
- Steering wheel
- Horn ring
- Horn switch
- Steering wheel:
Sanded and repainted - Horn ring:
Dechromed and then re-chromed using the classic copper–nickel–chrome layering process
Special feature:
The nickel layer was applied using a special “velour nickel” process, which gives the chrome finish a matte appearance, exactly like the original 1968 horn rings. - Horn switch:
Completely disassembled
Steel parts newly zinc plated
Plastic parts cleaned
New, custom-made rivets, also zinc plated, were manufactured and used for reassembly
- One horn ring is significantly heavier, as a large amount of copper was built up to fully close pores in the base material
- On the second horn ring, this was avoided by extensively sanding the base material before the first copper layer, removing most of the pores in advance
- The heavier horn ring can be sold separately
- The steering wheel, second horn ring, and horn switch are sold only as a set
$1500 shipped.
