1968 Magnum wheels question
HEMIVISION
6:03 AM
London Ontario
Hi There..I am going to do the disc brake coversion on my 1968 Satellite..I am using an 11 inch rotor..I have the five spoke 14"magnum wheels on the car..I talked to the vendor and he said they are o.k. if they are disc brake compatible..Are the magnum wheels from 1968 good for the disc brakes.. I guess they look a little different from the backside if they are compatible and I will check that when I get home but for now does anyone know...these rims do not have the trim ring they are chrome where the trim ring would be..1968..If I would guess they wouldn't make different magnum wheels for disc and non disc brake cars....but stranger things have happened..
Wheels will be fine. You might run into problems with the 11" rotor and 14" wheel. I had to go to 15" Magnums to clear the calipers for the 11" rotors.
It sure sounds to me I will be getting new rims...I guess it will be a wait and see situation..Anybody else have some thoughts..
