1968 TT1 green?
91r/t
12:55 AM
Buffalo, NY
My buddy is trying to find a formula for TT1 medium green for his 68 Charger resto. Anyone on here have a formula from a TT1 car you did to share? He wants to use PPG base clear, but is up for any base clear formula now to even match to.
Check this page out. Should have what you need. I believe its the Avocado Green.
https://paintref.com/cgi-bin/colorcodedisplay.cgi?model=Plymouth&con=oy&year=1968&page=1&rows=50
This page has plymouth,dodge and chrysler versions of the same paint code.
https://paintref.com/cgi-bin/colorcodedisplay.cgi?ditzler=43647&rows=50&syear=1968&smanuf=Chrysler&smodel=Plymouth&sname=Avocado Green
Chrysler called it Meadow Green
Dodge called it Medium Green
Plymouth called it Avocado Green
All have the same paint code.
I believe I can dig up the formula if this is the color you are referencing.
Go to a Ppg dealer. They should be able to mix it with no problems. They should have the code in their books
Russ
I used this single stage Dupont for the engine compartment. Color tints should be the same as a base coat. I have 6 quarts of original lacquer if he's interested.
