FOR SALE 1969 383 Roadrunner Immaculate
mopar1985
3:31 PM
Louisville
Feedback: +0 / =0 / -0
Laser straight car all body lines line up perfectly as well as the hood gaps, pictures cannot do this car justice it's amazing at how beautiful the car really is. If you would like to see the car idling or anymore ?'s or pics please feel free to message me thx.
Fender tag code: 1st line top to bottom "A87 J25 M21 END
F8 F8 H2X X9 213 308450
E63 D32 RM21 H9G 219697"
1969 Post car Roadrunner 33k actual miles , car was took completely apart every nut, screw, wire, bolt has been completely reworked or replaced. Entire car was stripped down to bare metal every speck of it top to bottom the metal was treated with metal treatment chemical, the bottom and inside of the car was painted with POR-15 treatment then the bottom of the car was painted with enamel with hardener agent and hi-gloss paint over the POR-15, the inside of the car the floors, doors, and under the quarter glass all have dynamat sound deadening sheets . Metal replaced on car are left/right quarters, Trunk pan , and trunk extensions all replaced with AMD metal. Car was etched primed and then primed again, then painted with Glasurit materials the best money can buy. The black is so black and deep it looks like black chrome "BEAUTIFUL" this car has no knockoff trim, horns, bumpers, door handles etc. all real date code correct parts!
Engine- 1967 High nickel block one made for A-bodies bored .30 over , steel crank, 509 cam hydraulic, edelbrock intake, 452 heads with hardened seats, 750 Holley carburetor, electronic distributor, MSD 8mm plug wires
Transmission- 727 torque-flite completely rebuilt with 2800 stall converter and trans-cooler the rear end is 8 3/4 open, 323 gear.
Interior- All PUI interior except carpet.
All heater control vents and fan motor work correctly with all speeds, wiper motor is a 3-speed and works properly blades are currently off the car.
Brakes are brand new the car is fresh nothing was left untouched on this car!
ASKING 35K FEEL FREE TO MAKE AN OFFER!!
LOCATED IN LOUISVILLE,KY
Thanks B-bodies for letting me post here!!
