SOLD 1969 4-speed Transmission
hunt2elk
3:26 PM
WI
Feedback: +154 / =0 / -0
Mopar A833 4-speed from a 1969 Plymouth Road Runner RM23H9A458254. 23 spline. Stock 4.805 bearing retainer.
Uncut shaft. I had it gone through several years ago by a professional shop. I put about 4000 miles on it behind my original 383 motor. Add some 80w-90 oil and bolt it in your car. Located in west central WI, 100 miles straight east of the Twin Cities. $1400.
Thank you for posting the VIN pad. The VIN (458254) is from an error at Lynch Road on or around September 17th of 1968. It is a new VIN to my database.
Good luck with the sale.
D
Thank you for posting the VIN pad. The VIN (458254) is from an error at Lynch Road on or around September 12th of 1968. It is a new VIN to my database.
D
Didn't know you kept track of such things Darrin, since this would have never been in an A12 car. What do you mean by an error?
? Should be "158254" ?
The VIN was incorrectly entered. If you look at the keypad on your computer you can see what maybe happened. The first three numbers most likely should be 125 vs 458. The person doing the input had his hand up one row on the keypad.
But, I think it is more than this as the known range of VIN in question is from 457993 to 458857 and there are actual 125xxx VIN in between 124993 and 125857 as corrected. More than one person doing input?
As a friend of ours here says - "Research continues".
D
Sold, thanks FBBO.
