SOLD 1969 Coronet
FranksCoronet
5:25 AM
Wilmington Delaware
New :
  • Brand new gas tank and fuel pump (went through the whole fuel system)
  • New Brakes all around (new master cylinder, brake line, wheel cylinders, and rebuilt each wheel)
  • New Wheels and tires ( 15 x 7 police wheels with caps, Brand new 235/60/r15 Futura GLS tires installed in 2021)
  • New Aluminum Radiator (Champion)
  • New Tach (Mopar sweep tach)
  • Electronic ignition
  • Replaced Turn signal switch
  • Electric secondary fan installed
  • LED Headlights installed (have the high beams and the originals)
New engine stuff :
  • Heads completely rebuilt
  • New Water pump + timing chain
  • LD4B intake + carb
  • Engine gone through
Relatively rust free, 318 auto, 8 3/4 rear. Lower quarter has some rust, have replacement. Only other rust spot is quarter sized hole on drivers floor. I daily drove it all summer, kept up on oil changes and maintenance throughout my 3 years of ownership. I have receipts for the engine work. Only selling because a friend is selling a truck I've wanted for a while. The only issues I'd address on it soon are the front doors sag a little. I will be including new door pins, and I have spare hinges in case the hinges are too worn
Parts included :
  • A12 Replica fiberglass hood + pin kit
  • A box of spare taillights (4)
  • 1969 Super bee Decklid
  • Lower quarter from AMD
  • Hooker headers
  • Full size 15 x 7 spare with brand new Futura tire (235/60/R15)
  • Drop base air cleaner + carb spacer
  • "New" speedometer reset to 0 miles
  • Miscellaneous spare parts (door pins, headlight switch, brake light switch etc)
I'm sure I'm forgetting some stuff, but it’s a solid and reliable driver, not a speck of rust on the frame. I'm looking for $6,800 OBO for the car and all of the parts included. It does have a valid Delaware inspection through 2024 and a clean and clear title. Might entertain trades, Location is Newark, DE. I've put a lot of work into making it a solid, reliable driver and I hate to see it go.
Trying to reach you about this but your inbox is full. Can you send me a message and let me know if it’s available?
