1969 roadrunner 383 fuel sending unit
paul1969cars
9:06 PM
new york
Hi
I need to replace my sending unit in the tank.
This is photo
the top line goes to engine
the bottom line is a dummy line and capped
is there a sending unit with just one output for the fuel so i don't have this dummy line
also what correct size 3/8" or 5/16"
5/16" main fuel line, if it's originally a 383cid
most all of them now I have seen
have an added 'return' 1/4" nipple/for later vapor canister line in most cases
so it's 1 style, can be used on many different years applications
I used it for a return line on the one I have
for a bypass-style fuel regulator
you can also get them in 3/8" for 440/Hemi
or custom 1/2" pick-up line too, for larger engines needs
they all look the same, for the 68-70 RR, just different sizes
good luck
