1969 Super Bee Horn Doesn’t Work
vektro69
2:47 AM
Troy, IL
My horn doesn’t work. Haven’t yet started to diagnose it, but some have said it’s missing a horn. Should have 2, but, has only 1.
Is this 1 horn just on Coronets and not on other B bodies? Seems Chargers have 2.
They all had two horns, a hi and a low, unless it was a roadrunner with the single Beep Beep horn.
I've found it's usually the horn itself.
With the car off you should be able to hear the relay click in when pressing the wheel button or horn ring.
Clean up and tighten the connections at the horn and body ground.
You can try taking a hot wire from the battery to the horn terminal from the harness as a test.
If it doesn't work with the temporary wire try bumping/tapping the horn with a plastic hammer.
If it triggers or makes a little noise you've found where the problem lies.
Thanks for your help. Guess I need to find another horn somewhere
It should still function with one horn. If you find the issue and can get it to work, it’s just a matter of finding another one, either the high or low, and hooking it up.
