WTB 1970 B body convertible dash switch
Thank you 1 wild R/T! I had seen the second listing which was too much for me, but I hadn't seen the first one which is more reasonable. Was hoping to find one cheaper but when you need it, you need it. Thanks again
Looking for a 1970 b body dash convertible switch for my 1970 Road Runner
I might be wrong here....but If I recall correctly ...the Convertible top switch uses the same toggle as the Rear Window Defogger - just turn the 'knob' around - same base and switch - and the same knob - typeface on both sides.
So you could also ask for the rear window defogger switch.
The convertible top switch and wagon rear window switch is the same, different switch for defrogger. The top/rear window switch is spring loaded, the defogger is three position. You can also tell the difference by wire colors also. All info found in the thread below.
