WTB 1970 Console Pistol Grip shifter
Chris66
12:38 PM
Rochester, NY
Feedback: +1 / =0 / -0
Looking for a good used or reproduction pistol grip console shifter.
Just the handle or handle and shifter body. I have the rest, other than the backdrive parts.
thanks Chris
I have a 70 shifter body, but no handle if that would help you any
Still looking for the console handle, prefer the bolt on style.
Have shifter bodies, just need the right stick.
Reproduction piece is fine.... thanks
Chris66,
Do you have a pistol grip mechanism? The lever arms that hang below are significantly longer on the pistol grip mechanism to shorten the throw of the shifter to around 8 inches total....a standard mechanism will most likely increase that to longer than 12 inches total. For the bolt in style handle...it will definitely be aftermarket.
It looks like the console style supply has dried up in all my searches....and the ones out there are expensive. Good luck with your search.
I have a 70 slip in and a bolt on aftermarket units.
The slip in are out of my price range generally, the bolt on's are out of stock for the moment,
so I am really looking for a console pistol grip that is a bolt on... thanks
