1970 disc brake rotor replacement
markymopar
7:48 PM
Basin Wyoming
I am in need of help to find replacement rotors for a 1970 road runner with factory disc brakes. I am trying to confirm interchange and fitment before ordering anything. Some sources for aftermarket rotors show 1970-72 but are 1 piece rotors. I am not concerned about.exact correctness but want something that will work without changing everything.
Also would consider 1 good use rotor if someone has 1 they dont need.
Thanks to Dadsbee’s alerting me as to your request ,
markymopar , I do have *** N.O.S. *** U.S.A. made ***
Front Disc Brake Hub & Rotor Assemblies…..
They started as 2 - piece Hub & Rotors , however , a
*** N.O.S. *** [ ONLY ] *** set of those are going for
$$ 1500 and up —- for a pair….
The whole world of that Hub & Rotor Assembly became a
1 piece Assembly in the 1970s ( for Liabilty reasons )….
I bought hundreds of them in 1996 , when Aimco / ITT ( out of business since 1997 ) was the last American Company to manufacture them…..
I also have *** N.O.S. *** Asbestos *** Front Disc Brake Pads —- the softest , smooooooothest, braking system known to mankind —- and do not rip up Brake Rotors to smithereens….
I also have U.S.A. Made Bearings and Seals , and U.S.A. made Brake Hardware — to “complete “ the package…..
The only bad news is that I am in New York and you are in Wyoming….. shipping is going to be a burden , for sure !!!
P.M. me , as per forum rules , if interested…..
And , yes , the application is 1970 - 1972 “ B “ and “ E “
— ALL — ONLY // 1973 & up is 1000 % different // and
1966 - 1969 is 5000 % different……
Yours, Craig …..
So will 1971 and 72 1 piece rotors work in place of my 2 piece rotor with no problems? Yes shipping will be expensive.
Yes — they 100 % fit , as I indicated above , 1970 - 1972 “B “ Body and “ E “ Body — ALL — ONLY —
# 1 ) I would “ bite the bullet “ and get *** N.O.S. ***
*** U.S.A. made *** Brake Rotors *** and *** N.O.S. ***
Asbestos *** Disc Brake Pads ***
As opposed to the Chineseum warpable Rotors and
Chineseum garbage material Brake Pads….
It is truly the difference between Loving Life versus
Regretting your decision to buy garbage…..
Yours , Craig …..
Do you have a replacement 2 piece rotors or single pieces only. I dont care about the pads but what would you want for a pair of rotors? Thanks
