SOLD 1970 Dodge Charger
garrett1308
12:48 PM
Texas
I have a 70 charger that I have decided to sell in order to buy a 70 roadrunner. It's a matching number 383 auto car. Needs restored. Has some rust in the lower quarters, trunk, floor, and around the front and back windows. No rust in the frame rails. Car is almost totally complete, only missing the air cleaner, one rocker panel trim, rear view mirror, and the antenna. Still has the original 2 barrel carb on the motor, so it was never hot rodded. Has a dent in the front driver fender that was drilled and pulled out, but other than that, I don't think it has one anywhere else. Has rust in the quarters, trunk, floors and around the front and back windows. No frame rail rust. Interior needs redone. Oil pan has crack in it, previous owner told me he put some sort of patch in it, filled it with oil, and the motor ran with gas poured down the carb. I have a new oil pan for the car, and once I get a 68 roadrunner of a lift, I'll install it. I have the keys, title, vin and fender tag. Asking 8250 for the car. It is located in Lewisville Texas.
IMG_4451.JPG IMG_4457.JPG IMG_4458.JPG IMG_4459.JPG IMG_4462.JPG IMG_4463.JPG IMG_4467.JPG IMG_4471.JPG
Fender Tag Reads:
E61: Blue 383 2 barrel, 290 horse
D32: Heavy duty 727 auto trans
XH29: 2 door Hard top Charger
L0G: 383 2 barrel carb, 1970, St. Louis
150098: Sequence Number
EB5: Bright blue metallic exterior color
C2XW: Black and white vinyl bench seat
EW1: White interior door frames
A27: October 27 build date
027972: Order Number
V1W: White Vinyl Top
A73: Special Value Charger XH29 Package
H51: AC with heater
M21: Roof Drip Rail Moldings
M25: Wide Sill Moldings
M31: Belt Moldings
R11: Solid State AM Radio
26: 26 Inch Radiator
End
Didn't notice it before, but a non original steering column is in the car. Not sure why. Has a few small holes in the roof, but it is solid around the hole; wire brush wouldn't widen the holes any. Needs trunk floor and floor pan. Grill doesn't have a single crack in it, but the wrap around for it does have one, as visible in the first picture. No plastic is missing from the crack and it can be repaired pretty easily.
The oil pan in the car is a good one ready to be installed.
Previous deal fell through, car is again for sale.
