FOR SALE 1970 Plymouth Road Runner 383 / auto matching numbers 36k
Jimclo2002
3:26 PM
Lewes, Delaware
Feedback: 3 / 0 / 0
1970 Plymouth Road Runner 383 HP auto/ matching numbers 36,000 $$$
VIN: RM23OGxxxxxx
condition: excellent
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 279
paint color: green
title status: clean
transmission: automatic
type: coupe
1970 Plymouth Roadrunner 383 A/T matching numbers engine and transmission. The car has been totally restored. Runs and drives beautifully as it should. Work and parts include ;
383 engine and transmission both have been rebuilt. I have documentation.
New wire harness forward light,engine,dash and rear harness
New brakes wheel cylinder, new springs (for brakes)
New upper and lower control arms and bushings.
New inter and outer bearings and races
Camber bolts/ nuts and washers taken down to metal
New headlightsso I splash shields
New hardware
New inter fender access gasket (black) new clips
New shocks and hardware
New stabilize bar bushing / hardware
New inter and outer tie rods new hardware
New power steering box new pressure hose and return hose
New power steering reservoir
Rebuilt water pump
New Grill
New hood insulation
New belts
New alternator
New coil
New voltage regulator
Rebuilt three speed wiper motor
New ballast resistor. Nos
New starter
New antenna
New speedometer cable
New door and trunk seals
Removed and cleaned proportioning valve for brakes
All new wheels on the brake lines from front to new master cylinder
New brake power booster
New Front, engine, dash and rear wire harnesses.
New 3 core radiator, new radiator cap, transmission cooling lines
New exhaust correct hangers and hardware
New gas tank
New gas tank straps
New gas tank neck
All new lines to carburetor, new fuel filter
Correct numbers carburetor rebuilt.
All chrome on car has been rechromed
All stainless on car refurbished and rebuffed
All New tires including spare !
New carpet, new seat covers, new vinyl top, new headliner
New handles inside (chrome)
New parking lights on side of car
New running lights front of car lower
New reverse lights
New front windshield
New driver side windows
New vent cables
New fuzzy strips inside and out of door
New door seals
New trunk seal, new trunk mat
The Road runner was re assembled with the correct hardware or the the original hardware was restored
Transmission has been rebuilt
Rebuilt shifter w new lens
Engine has been rebuilt
video on request.
pm me if interested
image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
