WTB 1970 Roadrunner/ Satellite key switch harness
Highwaystar
10:42 AM
S.Central PA
Feedback: 4 / 0 / 0
I'm looking for the small wiring harness that plugs into the yellow column key switch wire and plugs into main harness. I believe there may be some other connections, and feeds as well. I do not want the one with seat belt buzzer.
???? any pictures? There are no seat belt buzzers on a 1970. There are key in buzzers and those connect to a little 2-wire switch that is activated by the key. That's the only one I'm aware of
I don’t have one to sell, but I can help with a pic. It’s the 2 red wires in the pic. You’ll have the zoom in to see it, best pic I got.
I actually can use that red wire with small switch as well, but what I'm looking for is the connection to the single yellow wire that comes out of the column with the two main harnesses. There is a small harness connection to that wire to the main harness. I have seen them tyed into the flasher.
This is the single yellow wire to the light on the key switch.
Here is the yellow light to switch, I have that. The Harness to the flasher is what I am looking for.
I found a picture of what I'm looking for. This little harness.
I have one of those. PM me and I will answer tomorrow with pictures if you are interested.
