1970 roadrunner vin locations?
max340
5:58 PM
San Diego
Ok. Fender tag gone, and build sheet. Just want to make sure it is a real RM car. What are the things to look for and the things that make you run? Thanks, Tyler
I'm sure others will chime in, but I believe that the 70 should have the vin on the radiator support as well as under the weatherstripping in the trunk, on the drivers side.
I thought that was the locations for the sequence numbers. My 68' has them there.
I believe that changed in 69? I know that the vin is there on 69... Pretty sure it's the same for 70.
For 1970 The Vin# would normally be on the radiator support, under the seal of the trunk lid driver side, and another location That both my 70' challenger and 70' duster had was on the driver side engine cowling, just under the hood itself, on the horizontally flat surface. near the windshield washer hose. Another friend of mine said he also found it under the speaker tray behind the back seat. I was told that after I sold mine, so I never verified if mine had one there. Also the Vin tag itself, and it is also on the fender tag.
