1970 RR Hydraulic Safety System Switch ???
Lucky Lar
4:07 AM
San Rafael
I just noticed a loose wire with a connector hanging down near where all the brake lines connect
looks like there is a place to plug the wire into . anybody know much about the switch
That's most likely the Brake Light Warning switch connector. It hooks to the brake light warning light on your dash cluster at the bottom left and lights if the system loses pressure.
Thanks for the info, i just happened to see this after owning the car for 8 years
Where all the brake lines connect it sounds like the brake distribution block. There is a switch on the block that a wire should connect to.
Where all the brake lines connect it sounds like the brake distribution block. There is a switch on the block that a wire should connect to. I will test it tom orrow
Where all the brake lines connect it sounds like the brake distribution block. There is a switch on the block that a wire should connect to.The previos
Yes , i have a feeling the previous owner might have disconnected it because it was not working properly
