1970 steering column
Seventy
Banned
2:02 AM
Connecticut
Hey guys another question, I have a 4spd column, is there supposed to be a bearing in the bottom of the column, between the middle tube and center shaft? I have the bearing that goes between the outer tube and the center tube, but my shaft is just floating in the center tube, there are no holes or anything to put a bearing???
Yes the center shaft it is supposed to float at the bottom of the jacket. There is no lower bearing for a floor shift 70 Column it takes a nylon/white plastic outer seal & wire clip on the lower part of the jacket with a foam inner seal. The one in the link above is for column shift automatic use only
