1970 Super Bee Wiper motor/switch
cpojon
9:17 AM
Cedar Rapids, Iowa
Have a 70 super bee that was an original 383 car that now has a 440 in it. The original ralley dash has a two speed wiper switch. I've installed a ramcharger fresh air intake and a six pack set up and had to replace the wiper motor with a three speed motor because the two speed motor stuck out too far for the air cleaner on the six pack to fit. Will that three speed motor plug into a two speed switch harness? Would appreciate some help on this one. Maybe one of you have put a six pack on and had the same issue. Thanks in advance.
You need to also replace the crank arm and nylon bushing (PN 2822273) and the switch needs to be replaced. If you only replace the motor and leave the crank arm and the switch for the 2 speed you'll bind the motor with the 2 speed crank arm and you'll have one speed only and it will not park except where you turn it off at.
http://www.passion4mopars.com/Mopar-2-Speed-to-3-Speed-Mopar-Wiper-Motor-Conversion_b_1.html
Old thread I realize but hopefully someone can use the info
