SOLD 1971 413 with 727 transmission
FJ6 v code RR
3:57 PM
Collins Ohio 44826
Feedback: +3 / =0 / -0
1971 413 stock bore, standard standard on 440 steel 4 speed crank with LY rods. New Comp cam double roller timing chain. Cam is a 477 truck cam new lifters, the lifter still need broke in to cam. 213 heads with harden seats. Has new water pump. The 413 is setup with rear sump truck oil Pan and truck hp center dump exhaust manifolds with the y pipe, also has the 2wd truck mounts.
The 413 can go in a car by just changing the oil pan and pickup.
The 727 is a low mile transmission pulled from a rv.
This setup is for the 72-93 dodge trucks will work in 4wd just needs the 4wd motor mounts. This will also work in the 61-71 dodge truck all needs to be done is change the oil pan and I have the right one to do so and motor mounts 440 source sells them.
The price is $3000
Location is Collins ohio 44826.
