69a100
- 2:42 AM
- Aug 22, 2012
You're getting a great squirt of gas with the throttle, 1st video you say with a external tank. Are you using clean lines & filter to the carb or other?
Do you know or have any idea on what your timing is set currently at? Someone may have changed it to where your at now. Take a marker and make a line across the distributor and the block. Loosen dist. hold down bolt and move dist. clockwise just a fraction, like 1 or 2 lines worth and see if what happens when starting. Your starter sounds a lot stronger, you must have a hotter battery now? Good Luck
