1971 gauge cluster removal
bbeep71
11:20 AM
Northeast
How do I remove 71 RR gauge cluster to change bulbs and lube speedo cable?
you don't need to remove cluster for that, Can be reached from under the dash. Better if removing Radio for room on that side
there is a small cserw that needs to be removed from the side, ( I think 1/4" ? ) what holds the radio face plate to the cluster housing. Need to remove the ashtray to get access to it. Rest of nuts are easy.... pots and rear bracket one
